- Joined
- 5 Nov 2024
- Messages
- 4,470
- Reaction score
- 2,189
- Country
I’ve not done many heating controls and wanted to know, on a standard 2 zone heating system with a combi, existing programmer is rated as 6 and 2.5A (resistive and conductive I think) can I swap to a lower rated 3A one? Since, surely the fcu fuse will only be rated at 3A anyway.
Also, the oddity, but me (gas engineer) and the electrician think it’s coincidence: The customer was complaining that when she put her heating on it works fine, but once the temperature drops and the thermostat kicks in again, the smoke alarms go off. I’ve been and checked the wiring, which seems ok, couldn’t see any shorts and the download from the heat/CO in the kitchen (where the boiler is) doesn’t show any CO. Nothing is penetrating the wiring, eg a nail in the wiring. No gas cooker and she claims it does this every time. I’ve swapped the alarms - previously the optical alarm with 9v battery backup to multi sensor fire alarms. Anyone else had something similar? It worked fine when I was there.
