Access and replace feet of Candy Grand'O Vita GVS169DC3 9Kg
13 Apr 2025
A couple of the feet of the washing machine in the title are loose. I cannot screw them back in.
This is the actual appliance.
I think i need to remove the front panel to check what happened inside, but I can't find anything online.
Do you have any suggestion?
Thanks!
2 feet are adjustable so you can level the machine. They never get tight. Is that what you are seeing.
If you want to have a look. Drain by removing filler. Pull machine out and lay on it's side
Do you mean that they are not actually broken?
The tumble drier is stacked on top so I would rather avoid moving stuff if I don't have to.
Get a stout piece of timber, you can slide under, to lever the front edge up, then try adjusting by rotating the legs as desired, until it touches on all four feet, level.
