- Joined
- 5 Nov 2024
- Messages
- 5,332
- Reaction score
- 2,515
- Country
Do you still have the bridge wire in at the wiring center?
Sorry for my ignorance, do you mean the short at the end of the room thermostat wires?Do you still have the bridge wire in at the wiring center?
YesSorry for my ignorance, do you mean the short at the end of the room thermostat wires?
Yes the old wall thermostat is removed and is shorted out at the terminal block. Before I did this, I had set the old thermostat to maximum. Disconnect inv and shorting out at the terminal block made no difference to the operation of the CH.
So I guess the next step is to fit another motorised head unit (I do have a spare) ?
Coincidenses do happenThe final suggestion was a faulty micro switch on the 3-way valve, although that would be a coincidence that the switch failed at the same time as swapping over to the Hive unit.
