- Joined
- 6 Jan 2021
- Messages
- 71
- Reaction score
- 2
- Country
I recently noticed a patch of around 16cm where the plasterboard in my dining room has bubbled up. Above and below the bubble area the plasterboard is dry. I moved in around 18 months ago and never noticed it before. This is an external wall that's next to my conservatory. It's occurred right where the conservatory down pipe in. The pipe never ran into a drain, it ran directly out on to brick work which used to slope down into the garden. Unfortunately where the pipe ends, 2-3 bricks underneath have sunk by a centimetre or two causing the water to pool.
I've removed the excess water and have now installed a 210 water butt to collect the water from the conservatory roof. Will the internal wall and outer brick work now dry out?
Should I dig out the bricks and put 2-3 more in and ensure that there's a outer slope so rainwater runs off into the garden?
Some advice would be much appreciated (pictures attached of wall and conservatory gutter pipe - now goes directly into water butt).
