toilet control cable removal (How do I remove this please?)
6 Mar 2026
I've seen Multikwik fittings like that. I think you push down and twist.
Should be a push / squeeze button / point on it
It than should pull up ( the blue thingy)
Could be as spline said though ???
What’s in that bottom horizontal slot ?? Some type of c clip ????
Does the big white plastic ring unscrew?
As others have said they usually have a release button on them. This is the closest I can find.
Failing that you can usually split the 2 halves (it hinges along the top) & wiggle it off. There may be a small screw in the hole
