Removing a toilet and sealing soil shute
4 Aug 2006
Lancashire
Hi
I can't find a post on this anywhere, therefore could someone please explain how I would seal a soil shute which is concreted into to floor of a ground floor toilet.
All I want to acheive is remove the toilet and put a washing machine in the space.
Do I need to inform BCO on toilet removal and sealing the waste shute?
Many Thanks :LOL:
18 May 2004
depends where i get sent
if you use one of these you can run the wmc drain into it
can if you want . they will prob tell you to bugger off tho :LOL: :LOL:
4 Aug 2006
Lancashire
Thanks for that Kevplumb.
Looking at the gadget am I correct in thinking you just push the big end into the hole in the floor and cut out the top and insert the wash mc waste in there?
Would it seal properly to stop any smells rising up and would the top of the soil shute need to be level with the floor or slightly lower?
And finally do BCO need informing?
Thanks :rolleyes:
18 May 2004
yes
yes
no ;)
31 Jan 2007
London
can if you want . they will prob tell you to b*****r off tho :LOL: :LOL:
whata are they called again?
4 Aug 2006
Lancashire
Hi again
I have bought the gadget and an adaptor to fix the washer pipe to. one final question is :- Do I need any sort of trap or do I just fix the waste pipe to the adaptor and away you go?
My main concern is the smells from the hole in the ground, will these gadgets ensure a good air tight seal?
Cheers
:rolleyes:
10 May 2006
Merseyside
Yes you need a trap on the washing machine waste, otherwise your washing won't smell very nice.
4 Aug 2006
Lancashire
Thanks for that Sooey.
Am I correct in saying a S trap at ground level with a long pipe 40mm out of the top to insert the wm waste. :?:
