Metal Storm Door Closer Stripped
15 Mar 2026
Canada
The closer on my metal storm door has pulled away from the holes where the screws went into the metal part of the door.
I have tried using larger screws but this soon pulled out of the holes as well.
Any thoughts?
Thank-you.
I do not have a rivet gun.
But if I had one, can I rivet through this area without access to the back?
Thank-you.
Freddie is bang on with this......pop rivets can be used blind so just what you need!
I'd go for 5mm diameter (officially 4.9mm but 5 is fine), around 10mm long or whatever.
All you need is at Wickes or B&Q etc, and the spreader metal around 2mm thick.
John :)
John :)
I'm assuming with Canadian flag and a 'storm door' the OP does not reside in the UK .....
