I understand that a looped supply involves two or more properties and the supply going into and back out of the cut out fuse and onto the the next property(s) such as shown here https://commercial.nationalgrid.co.uk/downloads-view-reciteme/430885
We've recently had an EV charger installed and we were identified as being at the end of a looped supply sharing a live and neutral with our neighbour. The DNO gave the go ahead subject to retrospective works and they've just been out to survey.
The friendly surveyor said it's not a looped supply as even though the properties share a single live and neutral supply each property has an individual live and neutral cable split from the main supply going to their cutouts (not easy to inspect from outside).
He thought the supply cables were sufficient for both properties but took photos and will report back to the DNO and they can decide if it needs upgrading.
Is the problem with looped supplies the max potential current to the properties on the shared supply cables and/or the fact that the connections for the loop are done at the cutout in a property?
Secondly anyway to identify the size of the black incoming supply cables from this photo, they look to be the same diameter as the external cables supplying the two properties?
The black supply cables are at least 25 years old and for reference the blue cable which has a larger outer diameter than the black looks to be double insulated and I think it's 25mm2 as each of the 7 strands look to be just over 2mm diameter.
We have a TT system so there is no earth supplied with the black cables.
The DNO seem happy and will make any changes they deem needed so the above is just my curiosity.
