Five years ago I had the unfortunate luck of finding myself a charlatan Electrician who advised me a rewire was needed on a let property. I created a thread here and I got some help, eventually getting a second EICR done by someone else - that passed - and obtaining a refund from the original Electrician (who clearly had taken a chance, got caught-out and wanted it to go no further).
Since then I've been wary... and made it my business to have more than a passing knowledge (although still very much a layperson) of the possibilities here. I've just had another EICR done on a property built in 2010... exactly five years ago it passed with only a single C3 noted. An Electrician I found via Checkatrade has just been in and has come back saying it needs "loads of remedial work". My spidey-sense started to tingle. He said he would send me a quote across and assumed that I'd want to proceed ASAP to get a PASS.
Before he sent the quote I asked him for some idea of what he'd found out... thinking, if he said something like rewire or new consumer board, I might start to know a bit about where he was coming from - and decide whether I could trust him.
The first C2 he raised was new consumer unit... his justification for that was that it is plastic and doesn't meet 18th edition regulations. I said I disagreed with that coding and, surely, it should be a C3 or, maybe, not coded at all - I said the regulations aren't retrospective for working existing installations. He tried to persuade me they are and that it's not an optional thing for me - at that point I took the decision that I'm unfortunately dealing with a conman again.
So, I'll need another EICR... but I'm thinking some of the remedial issues he identified to me could be things I should act upon. I know - for sure - the last Tenant thought they were handy and have added some sockets to the garage, some externally and they definitely changed over a light fitting in one of the bedrooms. Other stuff I am a bit wary of, because I don't know why they would need changing if they were installed from the property being built and aren't causing any kind of problem. I'd love to get some feedback to educate myself...
He had said:
C2 new consumer unit - this is the red flag to me
C2 change grid switch - I assume this in in the kitchen where you have fridge, washing machine, dishwasher switches in a single panel?
C2 pendant front bedroom - I wonder if the old Tenant just wired it up without any kind of box or something?
C2 fast fix not supported correctly on top floor - I think this is a socket with one of those plastic backboxes with yellow tabs
C2 cables not supported correctly in garage - they go across the rafters / joists diagonally
C2 cables clipped externally - are you supposed to have them in conduit or something?
C2 outdoor sockets damaged - I don't know how, I'd need to check - they worked fine when I checked the new Tenants in six months ago
It's fair to assume things change with age and use, but I find it hard to see how a property goes from nothing noteworthy to a plethora of C2s without skullduggery.
