Trying to identify my underfloor heating cold tails
3 Sep 2011
London
HI everyone,
We bought a house about five years ago, and it has a freezing cold kitchen, which we later learned has underfloor heating that was apparently damaged during a flood. Something tells me this isn't the case, and that it was just the electrics above surface that got damaged. I have done some investigation, and have uncovered a junction box under the kitchen cabinets that feeds into the wall. It's 6mm T&E.
Here you can see it going into the junction and emerging from the wall. This is under the kitchen units. It's not live.
At the consumer unit, the cable emerges, and goes into another junction box, with another piece of 6mm coming out with "underfloor heating" written on it. The cable has been cut and taped. Presumably, this went into a breaker at some point
My problem is that I cannot find where the underfloor heating would actually connect to this junction box.. the only thing under here that even looks remotely possible is this cutout in the kitchen tile:
I'm trying to put all this together to see how I can prove the heating still works, but finding the cold tails is my problem.
If anyone can shed some light based on these images, I'd appreciate it, I get there's little to go on!
You would need to both check the continuity of the circuit, and the insulation resistance, before even considering whether it was worthwhile pursuing.
I’m guessing with the copper it’s wet underfloor heating (ufh)? If so, surely new electrics could be run to it?
That's a gas line, unrelated to the heating
But as per my question, I'm trying to figure out where the cold tails are to connect the power to
The circuit is fine, I need to figure out where the cold tails are on the floor, but I don't know what they look like, and the picture are all I have to go on
There are two types of electric under floor heating, one uses resistive cable, the other some chemical impregnation, the former needs sensors to stop the floor over heating the latter one does not.
I fitted the former type to a wet room, there were three connections line, neutral and earth. The instructions required insulation to be fitted first, so when it failed the floor was still warm.
Since you say "it has a freezing cold kitchen" I would think something wrong with the installation, not just disconnected.
The tester
is not cheap, so likely cheaper to get an electrician.
