Boiler Issues
and its connection to fusebox going through the roof
I went to put the heating back on via the white switch next to the honeywell. The heat didn't come on. At the same time the weather was hail stones and suddenly awful outside. Went to check the boiler, it was off.
Those were the only two things different than usual. I've been using that white switch inside the kitchen for the past week (as it's been getting warmer so I mostly kept it off to stop the running charge for gas).
All the switches on the fuse box are on. Do you suggest I try a full reset there or anything else?
The only other thing I can think of, is that rodents have been spotted in the area and I saw one coming out of my garage the day before. Possible gnawing chewy situation up in that roof?
The hot water was still working minutes before all this happened.
