- Joined
- 15 Dec 2024
- Messages
- 40
- Reaction score
- 9
- Country
and its connection to fusebox going through the roof
So that's unfused and could be fused via another switch, or it's direct to the consumer unit, which wouldn't give the best protection. You haven't knocked a switch off anywhere have you? Seems more likely that the internal fuse has blown.
Buy yourself a 'voltstick', and learn how to make use of it. They are a very safe way for the unskilled to see what is live and not live, without needing to open things up, or disconnect things.Thanks for all the advice
Thanks for that. They recommend this too, to save money and to figure out whether it's a power or boiler issue.Buy yourself a 'voltstick', and learn how to make use of it. They are a very safe way for the unskilled to see what is live and not live, without needing to open things up, or disconnect things.
The person diagnosing in a quick visit said it was a very strange set up and advised me to find out whether it's the wiring or the boiler itself.
Not sure why he said that. All boiler's should be fed by a common mains supply. I would suspect that the fused switched unit beside the timer feeds power to the timer and that should also feed power the boiler, through that switch on the wall beside the boiler.The person diagnosing in a quick visit said it was a very strange set up and advised me to find out whether it's the wiring or the boiler itself
Who did you get to look at it? Strange either way.looking at an electrician or boiler repair at this stage?
what fuse had blown and what further fuses blew ?Had someone come out to diagnose. The fuse was blown, and further fuses would blow when all of the below were true::
And he told you to find out if the boiler or the electrics was the problem? Very strange.Boiler repair guy.
All fuses blown have been the ones inside the boiler. The original. Then the one he tested with after powering up. He gave me a third and I tested it by shutting down everything and it blew with the sequence described above when I hit the main power switch shown above next to the boiler. It would not blow unless the timer was set to "constant", even when the timer was powered by the kitchen switch.what fuse had blown and what further fuses blew ?
How do you advise I proceed in fixing the issue? He claimed he did not understand where the wiring is going back to the kitchen. I said "could it be going back through the power switch back to the mains and into the kitchen. He said yes, but it would be an overcomplicated way of dealing with it, when it just needed powering up and then to supply gas.And he told you to find out if the boiler or the electrics was the problem? Very strange.
