- Joined
- 27 Jan 2008
- Messages
- 29,214
- Reaction score
- 3,582
- Location
- Country
I looked at my software and noted a high load.
The 3313 watt load seems around 3000 watt too high, but before I could check the immersion heater load had dropped. This
does not seem long enough to be the immersion heater. Second spike wife was out, so nothing she has done, the first peak
seems to follow the solar production, so that would seem to tie in with iboost+ but I can't think of anything other than the iboost+ that could use 3 kW, but the time seems too short.
It may be that a thermostat will do this, and nothing wrong, but I would have expected a thermostat to stay energised for longer. But until yesterday, this year there has not been enough solar for it to use a full 3 kW, so not noticed those spikes. But can't think of anything else which uses 3 kW. Monday and Wednesday both high solar, and it seems similar both days, so is once every 2.5 hours about normal for an immersion heater to cut in?
seems to follow the solar production, so that would seem to tie in with iboost+ but I can't think of anything other than the iboost+ that could use 3 kW, but the time seems too short.It may be that a thermostat will do this, and nothing wrong, but I would have expected a thermostat to stay energised for longer. But until yesterday, this year there has not been enough solar for it to use a full 3 kW, so not noticed those spikes. But can't think of anything else which uses 3 kW. Monday and Wednesday both high solar, and it seems similar both days, so is once every 2.5 hours about normal for an immersion heater to cut in?
