- Joined
- 6 Mar 2009
- Messages
- 202
- Reaction score
- 11
- Country
Water co recently turned off the local supply to carry out some work - unfortunately the supply did not come back on fully, meaning just a trickle/drip from the cold taps - all neighbours appear fine. The suggestion is that sediment or silt has got into the pipes and blocked a tap/valve somewhere, but after three plumber visits (contractors to the water co) we have no idea where - the water main outside supplies three different properties, and there is a stopcock on each split supply as it enters the building - “ours” has been replaced with a lever valve with no effect. Stopcock to the combi boiler has been replaced as it was seized, again, to no effect. The plumbers made various attempts at blowing back down the pipes with a compressor, and (three days later) we did get more flow from this, although still not enough to turn on the combi boiler for hot water. There is a brief rush of rush of pressure when opening a cold tap before the flow goes back to a trickle.
The issue is that there is no evidence of a stopcock or valve anywhere else (eg under the kitchen sink, bathroom basin, or where the washing machine plumbing is) - the cold mains water appears to enter the (1st, 2nd and 3rd floor flat) via a 1st floor bathroom from boxing (with no access hatch) on a communal stair, and there appear to be two copper pipes disappearing underneath the tile-over-ply bathroom floor which are visible from the bath and lavatory plumbing. The bathroom basin taps are supplied from PVC pipes which also disappear under the floor.
Nine days later, the plumbers are intending to rip up the bathroom floor with the expectation of finding a stopcock or valve, which seems pretty unlikely to me - is it not more likely to be found inside the boxing before entering the flat? Could there be a blockage from sediment which isn’t at a valve? Suggestions for a course of action welcome…
