contrails (chemtrails)
This is referencing weather control by other means - not chemtrails. The US middle east basses that have been hit, the idea is that the bases were using some sort of radar to control rainfall. And now those radars have been put out of action or disrupted - its now raining like it hasn’t done for 15 years
Not to worry, Noah will be along in a minute.
There's no evidence of any other method being possible than seeding clouds. You can't make clouds if they aren't there, and seeding is only for small areas. No evidence that Radar can do magic.
The Iranians sometimes seed clouds themselves, it says here.
I haven't read all this thread - presumably someone has pointed out that if air is supersaturated with water vapour, a plane going through it will nucleate condensaton, making a contrail.
Same mechanism causes water on plane wings, which can freeze and bring em down.
We are not talking about making clouds in this case - its keeping them away. Its long been talked about but labelled as conspiracy - as per standard Just found this
Well then you need to read it all to understand the difference between a con and a chemtrail. In a nutshell one is short in length and dissipates within 5 mins and the other goes from horizon to horizon and does not dissipate but instead it stays for hours upon hours and spreads ot joining all the others until the once blue sky at 11am by 4pm is now just a white milky blanket vastly reducing the suns power. Look up once in a while and you will see for yourself.
You do realise the by products of jet engines are nitrogen, carbon dioxide and water- right?
As Nitrogen, Carbon, Hydrogen and Oxygen are chemical elements, can you explain the difference between the 'chemicals' in chemtrails, and the chemicals in contrails?
How long the condensation clouds last depends on atmospheric conditions - like any other clouds.
Jet engines would produce much the same products as a petrol car engine, warm water vapour, CO, CO2, Plus some SOx and NOx.
OM fugging G. :oops:
That's just nuts.
For a start it's from a claim from an Iranian embassy in Afghanistan, so technically speaking you're falling for Iranian propaganda.
As you keep saying when you deny climate change, extreme weather happens sometimes. Just because it happened now doesn't mean it was caused by rising CO2 or malfunctioning microwave ovens.
Although I am curious how these radar systems work. How do they differ from normal Radar stations? If they can control the weather why use 'chemtrails'. How can they stop rainfall over Iran when they're so far away from Iran? Do they have a defrost mode? Do they have a grill setting? Has Which reviewed any of them to check how even their cooking mode is and how much they'll cost to run over a year?
:cool:
That's just nuts.
My mate Mr Wells, (Herbie to his friends) assures me that it's not malfunctioning microwaves, they're modified microwave ovens.
They turn the microwaves on their sides, and the turntable produces a centrifugal effect that keeps the radiation in a tight pattern for the desired distance. He tells me that they can control the distance by the speed of the turntable before the centrifugal effect dissipates, allowing the microwaves to reach the centre of the target area, and disperse.
Also, by modifying the top of the microwave, they're able to produce a barrel, like a rifle barrel, and the rifling on the inside helps maintain the aim of the microwaves.
Banks of these modified microwaves, all with slightly different target areas, produce the drought over large areas.
But it's top secret, so don't tell anyone. My mate Herbie had to go into hiding for telling me. I think he's hiding in the futuristic Chinese vertical farming towers. He's doing some work for the Chinese on ultrasonic aeroponic systems.
He sends me a postcard occasionally, but as it's in code, I can't read it. And even if I could it would be in Chinese.
What is the link between the irrational boll ox the chemtrail (and other) conspiracy theorists come up with and the Trumpf loving right wingers. Intelligence or lack of it?
That's just nuts.
The old claim is by Iran yes but the "coincidence" is there for everyone to see and does back up what they have been saying all along.
Now you are being silly. Its probably not radar its something else. HAARP ?
