Cant open central heating return valve on boiler
15 Apr 2018
Hi All,
I was changing the pressure sensor on my GLOW WORM UTRACOM 30 CXI . I followed the instructions posted elswhere here (turn off boiler. Turn off CH flow and return)
I managed to get the return valve off but could not get the Flow valve off, so I drained the whole system.
I now cant turn on the return valve (the right side pipe on the boiler)
I am thinking I will have to swap out both valves.
But in the mean time, will I be able to use the boiler for hot water with the return valve shut?
I was intending to pressurise the system so we could get hot water, buy some new valves, then drain again and fit the new valves.
As an aside, I presume there is no point putting rad inhibitor for a week or so?
Many Thanks
Ohhh.
Nothing my area but I'm not liking your Idea.
A mate burnt out his boiler messing with it as it was unable to cool itself using radiators. He got the hot water going but it caused something to fail inside.
Hi All, war the knights
Many Thanks
If the valve remains difficult to turn, consulting a heating system engineer might help avoid unintended damage.Thank you for sharing information!
