I want to activate an output when the main power is cut off, but outputs "Aera - Fault Present" or "System - Mains Power Off" do not activate when the main power is Off.
Panel : Premier Elite 48W Live
Software version : 3.0
When I cut the main power, the alarm is displayed on the keypad but the output does not activate
Output setting : Output Group - Area / Fault Present
Installation Manual documentation :
66 - Fault Present : This output type activates when a general fault occurs i.e. Line Fault, AC Mains Fail, Detector Fault etc. and deactivates when the fault is cleared.
