I have a number of units which all use the same batteries, gardening tools, multi-tools, drills, the last one was an angle grinder, the batteries are available as 2, 4, and higher amp hour ratings, and with the gardening tool using two batteries at a time, the 2 Ah gives a good balance to the tool, and at 40 volts, it does have enough grunt to do the job.
But the angle grinder only uses one battery, and it also uses a lot of power, so I bought a 4 Ah version of the batteries. The odd thing is nearly the same weight and size to the 2 Ah version, it also has Bluetooth to tell my phone its state of charge, and will allow me to set discharge and charge rates, and counts how many times it has been charged. Not a clue why, but it does mean if I buy a second I will be able to use my gardening tool for far longer.
At the moment I could easy in error fit a 2 Ah and 4 Ah in the garden tool, which I assume could damage the 2 Ah battery? Maybe no one remembered there was a tool that could use two batteries?
