Hey, thanks for helping.Please please please don't use pushfit waste pipe fittings. They can be a problem just waiting to happen. If you are going to that trouble doing the work then always best to use solvent weld under floors.
If it's 32mm waste then usually no issue to core a hole, with the depth of those joists. You are allowed a hole up to a 1/4 of the depth of the joist, in mm (e.g - 50mm in a 200mm deep joist)
The 1.5" (40mm) waste pipe will all be solvent weld. I assumed it was pushfit pipe as it was pushfit connections into the 4" soil pipe.
The pushfit pipe was quite loose though into there so I went and tried my solvent weld pipe and was much better fit.
So everything is solvent weld, except the 4" connection into the soil stack, and the 2x waste connections into the 4" pipes.
These connections appeared solid originally so hopefully all is well. Can you buy new seals for these or is there a chance they don't fit?
So far iv just cleaned up and applied fresh silicone grease.
