I was having a look at the waste/trap that come with an IKEA kitchen sink. Isn't UK standard gear. Can they usually be swapped for a normal basket waste? Imagine depends on the overflow as well. It's a square overflow
As long as it's a standard ~90mm waste hole then the McAlpine basket waste will be fine, that's one thing that all sink manufacturers seem to align on.Thanks will a normal basket waste fit with a square overflow?
Can you not just fit the basket and overflow, then replace the trap if you want to? Is the bottom of the basket waste a normal thread?Thanks just hope the overflow fits a normal basket waste and overflow
Thanks so you had to replace the whole kit?No. Only fits their waste kit.
Been there done that.
Yes, unless you use the one that they supply.Thanks so you had to replace the whole kit?
Yup - and the McAlpine trap's diameter, with it's raised flange, is slightly larger than the IKEA waste so it won't fit unless it's modified, been there done that tooNo. Only fits their waste kit.
Every time - I've found it isn't worth the hassle. It lasts for a bit and then the seals start to give. As I tend to support my clients for a long time and since every one they have asked me to fit, eventually leaked, I just replace the whole thing every time now.Thanks so you had to replace the whole kit?
Just measure the square overflow to ensure the new waste overflow will fit, they do tend to be universal standard, that's the McAlpine one - BWSTOFRS
