20mm tungsten scraper and sand.
You need to remove as much rust manually as you can.
You can buy rust treatment but it won't work very well on deap rust, just use on what's left.
2 pack resin filler.
Sand
Paint.
I would consider a cover strip, as there looks like a joint which is letting in water causing rust..
Sand
Paint.
