Oh Dear. Unfortunately HRH Prince Phillip aka the Duke of Edinburgh is no longer around to tell youWhat does "extract their digits" mean?
Is that the type with LCD display giving time, date and day/night kWh readings? My brother's was that type till he went smart meter. I told Octopus I would be happy to change to that type but they wouldn't do it.The second most obvious solution would be to fit a dual-tariff 'dumb' meter (which is what I have), with a built-in clock.
I would prefer (slightly) to keep the functionality but it won't happen with Octopus and if I change supplier I doubt the new one would do it either.Failing any of that, and if one wanted to preserve the functionality that you had with the RTS, I suppose they could revert to installing just a simple local ('external') 'time switch' (in place of the RTS one) (probably electronic these days, rather than the electro-mechanical ones of old) - which is, of course, what millions of us had (rather than the RTS) in the past. However I don't see why they would do that, rather than fitting a 'dumb' dual-tariff meter like mine.
Sounds like a different system with 2 meters. Mine has 1 meter with 2 mileometer-type displays, the RTS telling it which one to use (till it was switched off)It started with an 'external' electromechanical time switch and two meters.
I have one of those as years ago I changed to a economy 7 tariff but never had any timed stuff but after a while I realised that despite changing my lifestyle to make use of the E7 it actually turned out that it cost me more because the standing charge and the day rate was higher than just a single rate so I changed back to a single rate.Is that the type with LCD display giving time, date and day/night kWh readings? My brother's was that type till he went smart meter. I told Octopus I would be happy to change to that type but they wouldn't do it.
Yes - well, that plus an awful lot more. It's almost a 'smart' meter, but lacks the comms module and a 'remote disconnector'.Is that the type with LCD display giving time, date and day/night kWh readings?
I doubt that any supplier will any longer fit anything other than a 'smart' meter. Despite some people believing that they can 'refuse' to have a 'smart' meter fitted, I suspect that we are gradually approaching the time when any alternatives will simply no longer be 'available' - so they would then have to choose between having a 'smart' meter and not having an electricity supplyMy brother's was that type till he went smart meter. I told Octopus I would be happy to change to that type but they wouldn't do it.
That was the second system I had here, other than that the switching was done by an external mechanical time switch, rather than RTD. However, prior to that there had been two separate meters, each with just one 'mileometer-type display', but that was changed pretty soon after I inherited it!Sounds like a different system with 2 meters. Mine has 1 meter with 2 mileometer-type displays, the RTS telling it which one to use (till it was switched off)
That's always been the case here - from start of my occupation to present, with 'everything electrical' switching between the 'day' and 'night'. tariffs'. There had originally been night storage heaters here, switched by contactors controlled by the same time switch as the meter(s), but they were out-of-service by the time I moved in.Everything electrical was at day or night rate, probably different if there are storage heaters or dedicated feeds to eg an immersion heater
Yes, in the absence of night storage heaters an E7 (or similar) tariff is usually going to cost more than a single-rate tariff for most people. I'm probably an exception, since by adjusted our 'lifestyle' (and doing most water heating by nocturnal immersion) we've managed to benefit from E7 so far - with generally about 50% of our usage being at 'cheap rate' (with most suppliers, 'break-even' is around 35%).I have one of those as years ago I changed to a economy 7 tariff but never had any timed stuff but after a while I realised that despite changing my lifestyle to make use of the E7 it actually turned out that it cost me more because the standing charge and the day rate was higher than just a single rate so I changed back to a single rate.
