Can I tuck the rubber behind the soffit? As in prize the soffit slightly and push some membrane up there. That would mean that water couldn’t seep down the rubber into where the join is…
I'm sitting right now in a 5m x 5m room with a flat roof that was built butted up to a pitched roof on a bungalow. The soffit and fascia were removed, along with some lower tiles, but the original roof structure remains untouched.
The ceiling's a bit lower than ideal, at 2.3m, but it's perfectly fine.
It can be done, if you want a proper room rather than a botch, all without major structural work.
I know. Needs some photos really, but I'd ask why build something so small onto the house at all? If it won't be entered from the house then it's probably best well away from it.
You could cause issues by making a wall of the house damp, either by trapped humid air or running off rain going in an unexpected direction.
