I've got a garage too small for a car that I want to partially convert to a room and have a couple of questions. The garage is attached to the house and has a cavity wall on the two external walls and a bedroom above, so is effectively another room with a garage door.
1) How should a joist be attached to the wall? The floor will need to be raised, as the rest of the attached house is 12" or more higher than the garage floor. I plan to buy big joists to place at the right height, but how should these be attached? Should I cut out a slot in the walls to fit the joists in, and rest the middle on stacks of bricks with a damp proof layer, or can I simply screw joist hangers to the walls and put the joist into them?
2) Is there anything special required for the false wall between the new room and the old garage opening? I plan to fit a new garage door to replace an up and over, with a hinged three way door and use the space for bicycle storage. I thought build a wall with DPC out of brick to the floor height and then partition wall above with decent insulation and plasterboard either side.
thanks for any advice
mike
mike
