- Joined
- 11 Dec 2012
- Messages
- 5,430
- Reaction score
- 2,849
- Country
They won't use it at woke lefty marches...Not sure
Case of Pot calling the Kettle black.Vinty = desperate obsessive. Himmy without the humour.
You are the one who is constantly starting threads about Muslims, commies, invaders and all that ****e.
I just respond to what you post to try an reassure you that things aren't as bad as you have been led to believe.
Far from it mate.Mr Britishophobic speaks!
Far from it mate.
I just find it strange that you equate a sleekit c**t like Robinson with traditional British values of tolerance and common sense.
Bewildering. Seems like a lot of hatred in there.I just find it strange that you equate a sleekit c**t like Robinson with traditional British values of tolerance and common sense.
He has a bet rep. But, his heart is in the right place...Far from it mate.
They set it up at Euston and Kings Cross train stations. If it only catches people going to the Race riot protest then that's no one's fault but the far right.They won't use it at woke lefty marches...
Two tier policing...They set it up at Euston and Kings Cross train stations. If it only catches people going to the Race riot protest then that's no one's fault but the far right.
Anti-British RWR hatred needs to be stamped outThey set it up at Euston and Kings Cross train stations. If it only catches people going to the Race riot protest then that's no one's fault but the far right.
So what should be done - wait till things are really bad, and perhaps irreversible, before doing something about it?I just respond to what you post to try an reassure you that things aren't as bad as you have been led to believe.
How you associate not wanting to be swamped by immigrants, and the country being islamified, with hating the UK is quite beyond me.Depends on how much you hate the UK.
If, like Koolpc and Spline, your hatred is turned up to 11, I guess that starting a race war would be what you think should be done.
Unless you are both of those thingsHow you associate not wanting to be swamped by immigrants, and the country being islamified, with hating the UK is quite beyond me.
