Disassemble Bed
Start removing bolts from the head board.
If it doesn't come apart it means it's been glued.
Then I wouldn't dismantle it.
Unfortunately, the OP wants new carpets fitted so it needs to be out of the room unless they cut around it.
My daughters house when bought had quite nice hardwood flooring in the bedroom......except for the bit the bed had sat on.
OP make sure you have decent screwdrivers and use them carefully. Mullering screwheads won't help. (and I bet your bed isn't as heavy as the wretched thing I'm currently dragging about to get under different bits of floor!)
Originally it went in through the door, either whole or in bits, so it either fits back out through the door without dismantling it or it comes apart.
My daughter’s house when bought had quite nice hardwood flooring in the bedroom......except for the bit the bed had sat on.
When we cleared my mother in laws house, we found that the carpet in the unused spare bedroom had been cut and fitted around a single bed! Luckily they had left the cut out piece in the wardrobe.
Yeah that is obvious, unfortunately doesn't help me though.
Coming apart isn't my main concern - I just have to keep unscrewing and I will find out what comes apart and what doesnt. The main question is - what is the risk of damage and risk of not getting it back together again.
Irrelevant if you want new carpets fitted - it has to be done unless you forgo having new carpets. Just go for it, it really won’t be hard. It wasn’t handcrafted and fitted on-site by a furniture master craftsman. Probably just assembled by a delivery driver with a screwdriver and a spanner.
Thanks. But dangerous to assume!
It was actually made on site by a carpenter / veneer specialist.
They used the template of an existing bought bed but they remade it in walnut / walnut veneer. So it isn't flat pack and definitely no delivery driver went near it!
Could be a problem. Can’t you get him back or at least give him a call?
Well just get on with it, I really can't believe it needs that much dismantling until you can fit the biggest bit through the door, then just put it back together, perhaps some additional brackets here or there or some extra screws will be needed to get it back together nice and tight but you gotta just bite the bullet and get on with it.
Yep I think that's it, Thanks.
I don't recall seeing the inside of the corners?
That's usually where beds come apart. :)
Not showing very much of the corner, also ISTR there are 4 of them.
Can you not undo the fixings in those corners to dismantle it?
Will it not turn on it's side and be carried out of the rooms whilst the carpet is fitted?
Carpet fitters have come across this problem before and may be able to fit the carpet to 1/2 the room, move the bed onto it then continue.
Talk to them.
