How do I go about this?
Yep, i`ll not disagree with that John, in essence. ... What I was attempting was , what is the best (easiest) way to refer to them in comparison, loosley we calls the current operated (RCD like, comparing currents) or voltage operated (comparing voltages) as a ready distinguishable different kind of "Earth Leakage Circuit Breaker" as we used to call them .....
Yes, I understand and respect the argument you are attempting to present. However, as I've said, I'm really not sure that it is particularly meaningful/useful to call one 'current-operated' ('current comparing') and the other 'voltage-operated' ('voltage comparing') - since both will operate when a certain current flows through them - which, again in both cases, could alternatively be expressed as the voltage across them required for a trip.
- but we changed that because they never did measure earth leakage they (both) compared either voltages or currents and made their conclusion.
As above, when only 'passive'components'(device coils in this case) are involved, current and voltage are directly, and linearly, related to one another, so one can express the 'trip threshold' as either a current or a voltage (in both cases).
In fact, neither of the technologies (OPDs or RCDs) we currently use for 'fault protection' actually look at 'earth leakage. OPDs only trip in response to the massive current (in L) resulting from a L-E fault 'of negligible impedance', whereas, as you know, an RCD just looks at the L-N current difference and trips if that difference exceeds a certain value. However, in neither case is there any certainty that a trip has resulted from 'earth leakage' - an OPD obviously may operate in response to an L-N fault, and an RCD may operate as a result of a connection or fault to another circuit.
It became apperent that in some instances the "voltage operated" devices could more often make the wrong conclusion under some circumstances, therfore the current operated devices where the more fit for purpose of those two types.
Yes, probably - although, as above an RCD can operate as a result of a fault (or erroneous connection) to the L or N of another circuit, without any 'earth leakage' being involved.
Of the two we've been discussing (RCD and VOELCB), I would have said that the VOELB is the 'closer' to actually looking at 'earth leakage' - although, as I've said, it will 'miss' any earth leakage going through a 'parallel path' (rather than going to the installation's 'earth').
Indeed the Current Operated Types (RCD etc) do not actually need an earth reference to be present to detect that problem in some instances in order to be able to "see and disconnect" in the case of a fault.
Quite so - but, as above, that makes them a bit less 'pure', since they can sometimes operate in response to situations which involve no 'earth leakage'.
So it`s just a case of the best easy name of the devices to differentiate their operation and therefore the inherent advantages of one versus the other rather than the fully correct explanation of their method of operation.
Yes, I understand that but, as I keep saying, I'm not convinced that,'technologically', there's as much difference in their 'methods of operation' as you seem to be implying. Both trip if the current through them is greater than some threshold (or, if you prefer, when the voltage across them is greater than some threshold) - and it would, today, be possible to make a 'VOELCB' which was as 'sensitive' as an RCD. I suppose that the main difference of practical importance is that the VOELCB will miss 'earth leakage' which goes to earth via parallel paths (possibly through a human being) - but it is also true that an RCD (but not VOELCB) can, in some situations, trip for reasons other than 'earth leakage'. 'Horses for courses', I suppose ;)
OK pedantic rules KO, yes the ELCB-v measured the voltage and hence current flowing between the bonding in the building and the true earth, so be it voltage or current, it is measuring earth leakage not live differential current.
We traditionally called a high impedance or resistance measuring device a volt meter/sensor, and a low impedance or resistance measuring device an amp meter/sensor.
Except for the valve volt meter or comparator we would draw power from the circuit and how much power was referred to as ohms per volt. I think the AVO Mk8 was around 20k ohms per volt. Still have one, but not used in years.
It certainly is operated by 'earth leakage' (provided the leakage path is through the earthing conductor) rather than differential current but, as I've said, one can express the trip threshold as either a current or voltage.
Although I suppose it is in some senses true, that seems to be a rather odd statement. The main reason why it is true is that if one did the opposite (tried to measure/sense voltage with a low resistance/impedance device, or to measure/sense current with a high resistance/impedance device) one could seriously (and possibly dangerously) affect the circuit one was looking at (and thereby invalidating the results one observed).
True, but I'm not sure what that has got to do with this discussion. "20kΩ per volt" in a traditional meter was merely a way of indicating that the actual 'meter' had a 0-50 μA movement.
We can use the Wheatstone bridge idea, 1779639216772.pngwhere we compare rather than measure, and the op-amp does just this. 1779639340237.png
It is a long time since I was in University and to remember how it all worked now not sure if I can remember.
I know the early RCDs did not use electronics to work as there was a worry about their failure, but latter we started to use electronics, by that time I was no longer a member of the IET and had stopped going to their lectures.
The early RCDs any slight warping of the case would stop them working, the latter ones seemed to be more robust.
We can use the Wheatstone bridge idea, View attachment 415249where we compare rather than measure, and the op-amp does just this.
Sure - a Wheatstone bridge can be used but, again, I'm not sure what that has got to do with our discussion.
I think that traditional 'valve voltmeters' (certainly the earlier ones) merely had the input connected to a valve grid, hence providing a very high input resistance, rather than being based on any sort of comparator. Similarly, I suspect that many of the current multimeters have the voltage-measuring input going to an FET, again ensuring a very high input impedance. However, as always, I might be wrong about some (or all!) of that!
John yes we are in complete agreement on all of this, I am purely looking at the name we use to differentiate between the two devices as a sort of "starter for ten" rather than being technologicaly correct, I`m happy enough with the two terms Voltage Operated v Current Operated in this respect although yes it could be misleading to some.
I suppose if we called one of them an XYZ123YabbaDabbadathing1 and the other type a XYZ123YabbaDabbadathing2 would certainly be better but rather cumbersome in usage.
Actually, not just the names I mentioned but there must be other names with equal or better merit to solve the problem.
Unfortunately none spring to mind at the moment.
If you think of something I will definately vote for it sir.
I think we've done this discussion to death, and it's really only an academic exercise - since it relates to seriously-obsolete technology and terminology that was established decades ago! ...but, yet, I find that terminology potentially misleading. However ...
I suppose if we called one of them an XYZ123YabbaDabbadathing1 and the other type a XYZ123YabbaDabbadathing2 would certainly be better but rather cumbersome in usage. .... Actually, not just the names I mentioned but there must be other names with equal or better merit to solve the problem.
Unfortunately none spring to mind at the moment. .... If you think of something I will definately vote for it sir.
I don't think either of us need to do any thinking to come up with new terminology to differentiate between the two types of device we've been discussion, since perfectly terminology already exists ...
Earth Leakage Contact Breakers (ELCBs)​
respond (only) to the existance of 'earth leakage currents'.
Residual Current Devices (RCDs) respond (only) to the existance of 'residual currents (L-N current differences).​
'Simples', isn't it ? :-)
Well so long as nobody refers to them as a Ground Fault Circuit Interupter or something I think it might be OK ;)
Even that doesn't sound too bad to me (for the ELCB) (once one has translated 'Ground' into English) - although I suppose some people might take it to imply that it is the path to earth, rather than the L+N, that is being 'interrupted'.
Well, it is a good job that people do not talk about a system that includes the earthing (or grounding) of cars etc or else we would all need to drive around with straps of rubber stuff conducting from chasis to the road surface
Well, that describes the very car in which I was driven around in the mid/late1950s ;)
Not a lot worse, I suppose, than the interesting situation which arose (in UK) in subsequent decades as regards 'bonding' :-)
Bonding has the potential (excuse that word "potential") to make installations safer, although it can also have the opposite effect of making things unsafer - a bit like the seat belt scenario, thought to predominantly improve safety yet under some conditions increases the danger.
The outcome is, in most things in life, "play the numbers game" (and hope for the best). Whether you are bonding/use seat belts/decide to cross the road today/drive a car somewhere/have a vaccination/visit a GP surgery - odds are never 100% or 0% but somewhere in between.
Bonding has the potential (excuse that word "potential") to make installations safer, although it can also have the opposite effect of making things unsafer - a bit like the seat belt scenario, thought to predominantly improve safety yet under some conditions increases the danger. .... The outcome is, in most things in life, "play the numbers game" (and hope for the best). Whether you are bonding/use seat belts/decide to cross the road today/drive a car somewhere/have a vaccination/visit a GP surgery - odds are never 100% or 0% but somewhere in between.
Quite so. AsI recently wrote, what is needed in such situations is a risk-benefit assessment/judgement/analysis - the outcome of which may vary very widely ....
In the case of seat belts, the probability of them doing harm is so low, and the probability of them doing good so high, that it is a no-brainer to conclude that, 'on balance', they are worth using. Much the same is probably true of "... crossing a road today/driving a car somewhere/ having a vaccination/ visit a GP surgery ".
However, the situation with bonding is not quite so clear cut. However, in many cases of 'unnecessary' bonding (certainly with some of the 'sillier' cases), it would seem that the probability of it 'doing good' is very small but, from the point-of-view of a person in contact with a live conductor/part, increasing the amount of 'unnecessarily earthed' touchable metal around (an inevitable consequence of some unnecessary bonding) will appreciably increase risk - so, on balance, the conclusion probably should be in favour of not installing unnecessary bonding (of otherwise unearthed things).
A bit of toing and froing on this but for the time being have decided against learning electrics as I don’t feel I have the right mind set currently to do it. I might go back to learning woodwork, but who knows. Vicious cycle atm.
