Looking to buy a decent wire stripper .. for DIY only
13 Feb 2006
Tyne and Wear
I am thinking about buying a set of wire strippers.
I am no electrician, just an average DIY'er but daughter keeps asking me to wire this and wire that.
Usually I strip wire with a Stanley knife blade, then do the same with the internal wires .. nearly always cutting one too short, then I have to start all over again.
Surely there's a better way
i have used many strippers over the years
these sort of strippers i like, not sure what i purchased a few years ago - but they where on a dela and i got a set for my son-in-law as well for car work
just went and found the ones i have, used a lot , wired up a garage and many circuits , son-in-law had the sparky on site doing a lot of other work and also signed off , and completed the work at Consumer unit - as she was onsite and saw the work from start to finish
You are the first I've known who gets on with those, one company I worked for were presented with one - highly recommending it in fact - by a wholesaler, it got passed around and eventually left laying on a shelf of random tools,
most I know prefer tools along the lines of these
Personally I used to love this style https://www.eurocarparts.com/p/amtech-auto-wire-stripper-553991250?
when they used to be made to a good standard but sadly haven't been able to source a decent one for years
Oh and don't be tempted to join the popular fashion of - let's say - less skilled persons by using cable cutters of this style
which invariably damages the copper
I have a pair of the CK ones mentioned. I am also DIY.
So easy to use.
Never tried Haupa, I had some Hilka for years until some /£()!n£ 5&!7head tried cutting 8mm Galvanised steel cable, when that did nothing more than rip a hole in the cutting edges he used the matching 10" cutters and again damaged the cutting edges, leaving only the matching 12" pliers... except all 3 disappeared until I found them in his tools on a subsequent job. I purchased a Wiha shears as I like Wiha screwdrivers, it's OK but I preferred the Hilka. I always find good results from Knipex.
I've seen a few using Jushin and Bahco but know nothing about them other than an occasional borrow.
BUT If... If I could justify the cost... Lindstrom. Heck they are just like an extention to the hand and so smooth.
