cant find the fuse box
Well using my link you copied to post 11, I was able to register a new enquiry, confirm on map and now await each utilities response.
So is your attachment the full screen or just part, there should be some columns on the left & a "NEW" button top right of page.
If it's an old cinema, you're probably looking for something a bit bigger than just a "fusebox". Probably a small plant room full of industrial switchgear.
Far from a certainty, but such things are usually in the basement because that's where the underground services will normally enter from the street.
So looking for a small room in the basement first
No it is just half of the top of the screen. if i scroll down I get a "recent history" box. In that box it says "no data availbie"
The only coloums on the left is what are in the screenshot. I new button thanks
But now I think about it i dont think this will work for me
because its going to take to long to get the data and it will not show where in the building to look for the meter. and i dont understand how to input the coordinace anyway
I would be very wary of turning anything back on until it's been looked at by a competent electrican with appropriate experiance.
Most likely I suspect you will want to set up a temporary supply with a small amount of fixed equipment in the mains room. supplying extension cables running round the site and temporary lighitng. So that you have a source of light and power while the rest of the fixed installation is repaired or replaced.
You should also start thinking early on about what you plan to use this building for? so that when you look at the electricty supply you can start to judge whether it's overkill, about-right or inadequate for your needs.
