Hanging lining paper around difficult areas
11 Jun 2016
Haven't done any wallpapering for donkeys years apart from a feature wall.
Its wallrock paper i am using. Straight walls obviously no issue, but it's just looking at all of the different external & internal corners i have to negotiate that has confused me & how to do it too. Especially where to join the paper on external corners without it being noticed.
Is there a YouTube video or similar that someone could point me to, any advice greatly appreciated. Many thanks
Well as long as the lining paper is well soaked, shouldn’t be a problem - it’s not as if you have any patterns to match. I always take my time with butting up the joins so that they don’t pull apart when it dries. Even then, if painting afterwards, you can fill any joining gaps with filler before painting. With papering, I’ve found that most mistakes you make are only obvious to others if you point them out!
