- Joined
- 19 Jun 2026
- Messages
- 2
- Reaction score
- 0
- Country
I'm building a rear extension with the joists running across the back of the house (not out from). It's going to be a cold roof with ventilated soffits at each side. So far I've built both skins to be exactly the same height, and I was planning to put wall plates on both and run the joist across both.
I (now) know that the 'usual', 'traditional', 'correct' way is for only the inner skin to bear the weight of the roof.
My question is why, what's the reason? What would the negative consequences or dangers be of using both skins?
I just want it to be as strong as possible. They are 9b3 and almost 6m long over 5m span, my inner skin is Thermalite, the outer skin is 7n concrete and I feel it would be a shame not to use their strength.
But I'll do whatever is correct.
Any advice will be gladly received!
Cheers
Cheers
