Makita 8391D drill - motor turns but chuck doesn't
20 Jan 2012
West Lothian
Hi
I have a Makita 8391D cordless drill. I was using it with a hole-saw on an old worktop when the chuck stopped turning, even though the motor was running OK. I can see that the shaft or spindle that connects to the chuck isn't turning. Does anyone know what part is faulty within the drill. Is the cost of replacement parts reasonable or prohibitive? (NB I did once try to repair a B&D corded drill (variable speed switch fault) and struggled to put it back together. I doubt whether I have the skills to do this myself.)
All assistance welcome. Thank you.
jumped out off gear /between gears??
is it making any unusual noises [clutch turned to 1??]
is there any feel off trying to work or just noise off a reving motor without any load
If it is a 2 speed drill ensure that the speed selector is engaged properly and if it is the same problem on both speeds
You could buy this £45 gearbox
Or this sub £30 entire drill, case, charger and more batteries
But it’s only £110 for a new warranted one that’s lighter and more powerful, whose internals are better suited to the increased torque and less likely to pack up again in the same way further along the same job..
(And if it does break out of warranty it’s easy and cheap to find a new body that works with your modern batteries)
Sidebar, 4 genuine MAKITA modern 6ah batteries for 120 quid; amazing
Many thanks to big-all, jj4091 and robinbanks for the very helpful replies.
I did what jj4091 suggested and found that there is a lot of 'play' around the centre of the 2-speed switch. The switch has to be pushed fully home for the drill to work correctly or else the fault will reappear. I will have to 'see how it goes' but I doubt whether I will work it so hard again; 38mm worktop is very hard to cut through with a holecutter.
robinbanks comments and links are also very helpful. Yes, there are plenty of working 8391Ds on the internet. BTW, I bought 2 new batteries from the internet last year for £26 and so far they are working OK; that is why I was reluctant to scrap the Makita or buy another one from e...bay.
Thank you again to everyone.
PS The video on YT showing the planetary gears in the gearbox is fascinating.
CHECK THE WORDING OFF "4 genuine MAKITA modern 6ah batteries "for 120 quid; amazing
THEY WILL NOT BE MAKITA
the batteries will look identical but where the words makita should be on the battery will some other wording like lion high power
they will say things like "genuine for makita" in the description and yes they are meant as a replacement but are knock offs
Yeah, the standard price for the real ones are about £280 (for 4)
