- Joined
- 19 Jun 2026
- Messages
- 8
- Reaction score
- 1
- Country
Hi all,
Looking for some advice please?
I have an old Ideal Concord WRS boiler circa 1979. Not sure if is a 230A/240A/255A. I am also not sure if it is gravity fed or fully pumped. There is a small pump to the right of the boiler
It has the programmer in the attached picture. Google Lens showed this as a Landis & Gyr RWB2, but looking for that on the net I see very different interfaces?
In looking for a replacment I found the Siemens RWB29SI?
In several threads on here, it is mentioned that the backplate is the same and that it is a straight swap. Siemens themselves state that. However in mine all the wires appear to go in vertically to the right side of the unit as you look at it's face.
Now I am not sure mine is indeed an RWB2, how hard would it be to replace this old timer please.
I do not intend to do it myself more than likely, but have a friend who could fashion some sort of mounting plate for the new programmer, then get an electrician in.
The current one is bolted to the boiler front panel with two screws.
Thank you
Edit: I now believe it to be gravity fed, as I do not have any controlled valves around the hot water tank.
Thank you
