- Joined
- 27 Jan 2008
- Messages
- 28,890
- Reaction score
- 3,533
- Location
- Country
Fan only 127 watts, where the pedestal fan is 37 watts, so even in fan only mode, it is a heavy power user. Rated to use 755 watts, I note actually uses 750 watts, it has dropped room temperature by 2ºC, where another room has risen by a degree, so all in all dropped 3ºC in 1 hour 45 minutes, which is the time set on the smart socket, so that it does not overflow the gallon container for the condensate.
So 3ºC for 1.4 kWh or 16.8p working on loss of revenue of the 12p/kWh I would otherwise get. Well yesterday ran out of battery due to using it, so an extra 32p but all in all, not worth sitting in the heat to save a few quid.
But how does it compare with a built-in unit, and at what point do we upgrade?
Old house never had an AC, this house, living room around 25 foot by 18 foot with two windows and a patio door, it catches the sun, so two options, stop using the living room, or run an AC.
I see reports of bans on using AC units by local councils, as it seems they need planning permission, at least for an external unit. I bet the council offices have it installed?
But last year used for around 3 weeks, so if that's the normal, then no point doing anything, the portable unit is good enough.
It does seem odd, one minute we are being told to fit heat pumps, the next we are told they need planning permission, and if not granted we need to rip them out.
