Replace traditional with bar mixer shower
19 Nov 2020
Ireland
I have an old unit that I cant source cartridge for and looking at replacement, will the copper pipes be long enough to replace with this unit?
'Fraid not, that connects the opposite way to a bar shower.
Your exposed shower feeds are tails that come through the wall, then a nut and olive is placed onto them (in essence a female connection) and then the valve's connections being male then fit onto the tails and connect up to the nuts/olive and then it's all tightened up.
A bar shower connects the opposite way, the shower has the nuts captive on the valve and that fits onto a fixing kit that connects onto the supply tails and that has male ends.
If you managed to get the nut and olive off the tail without pipe damage then you could try and see if they are long enough to fit a fixing kit onto them but I wouldn't hold your breath.
I didnt get round to doing this, then a video from BEAumber came up.in my feed.
With these fittings, I shoukd be able to fit the bar?
Video to what he did at 4:12
Is this realistic?
Thanks.
Hi
Yes they are 150mm apart, just was not sure they protrude enough for the fitting,this video seems to show a fix for that.
Also checked and hot is on left side as you look at shower.
OK.
You won't know till you expose them.
Could I use these to connect to BAR if not enough pipe for the provided fixings?
