- Joined
- 22 Jan 2007
- Messages
- 24,366
- Reaction score
- 3,649
- Country
The Pronto range from Topps Tiles are excellent, bit more expensive but are thicker and have built in underlay.
Our house is suspended timber floors and I've gone for tiles in large areas. In my kitchen I have 900x900 format tiles with no issues. The tiles in my hallway have been down for 6 years now. Again fine.I’ll take your advice mate.
It was my gut feeling and I was hoping to be convinced otherwise tbh
I’ve had commercial laminate for the last 12 years in my lounge that has been really good, but I don’t like laminate in kitchens.
At least LVT won’t be cold in winter
Not for glued down or tiles, but the OP is looking at a click system which needs little prep.Prep wise between the flooring not too much in it.
Was just about to say the same thing. I have never seen a decent looking/durable click LVT floor...I wouldn’t be going click LVT mate. Glue down always.
6mm hardiebacker on layer of adhesive, screwed down. Taped joints between boards and tiles on top using good adhesive. DIY install. In previous houses I've also tiled on top of timber sub floors using the same method without issue.
https://www.porcelainsuperstore.co.uk/blogs/help-advice/how-to-tile-onto-timber-floors
Incidentally I've purchased all of our tiles from the above supplier and they've been great. I'd go with porcelain over ceramic.
In terms of aesthetics I'd go for tiles- the only rooms I've gone for LVT is in bathrooms as I wanted something slightly warmer underfoot. The tiled areas look much better even though the glue down LVT I used is higher end karndean herringbone planks. Prep wise between the flooring not too much in it. LVT planks were a bit quicker.
Never had a problem with it, don't get cheap stuff.Why do you think click is bad?
Subjective of course but no match for real wood or nice porcelain tiles. It is plastic based/composite after all. Any click lvt will be also be prone to the click system failing with the slightest of undulations. If it has to be lvt (which I personally don’t think it does) I’d definitely be going for glue down mainly for that reason.Does it look cheap?
That’s my worry because it isn’t cheap at all.
My adhd takes me down a rabbit hole with anything I buy and man maths kicks in.Never had a problem with it, don't get cheap stuff.
Understood.My adhd takes me down a rabbit hole with anything I buy and man maths kicks in.
Trying to keep it in check with this
Decent stuff for less than half that, but tiles will be just fine.Some of this stuff is £80 m2
Understood.
So is it that the feet will sink in over time. The LVT is harder than that isn’t it ?If this is going in a kitchen think about heavy appliances like washing machines and fridge freezers which may cause problems with click LVT.
