Is that supply and fit, or just fit.Been quoted about £150 a door in my property, is this steep or about right?
I suppose yes because it will be more expensive for 1 door than each of 10 doors, once they have got the kit set upHow many doors?
My much much younger house was the samedepends on the doors and the door surrounds, doors designed for specific pre made frames already hinged and morticed - easy quick job
if its an old victorinan house with no two door frames the same, (corners not exactly 90°)
each door needs to be cut and plane'd to fit, all door furniture and hinges need to be morticed in - a day a door
Ii think Carpenters should be regulated amongst other trades that should be regulated.The problem is finding someone decent to do a good job.
If you have a few around you willing to take work on you can pick the cheapest.
If the tradesmen is good and busy they can charge what they want
Seems reasonable.Been quoted about £150 a door in my property, is this steep or about right?
