The scaling is pretty accurate, but it is, of course, based on the dimesnions of flat cabled, which varying quite a bit.If your scaling is anywhere near correct (it looks to be in the pic) I wonder why you are not looking at staying with 3C&E
As for your question, maybe your experiences are very different from mine - but it would seem 'obvious' to me that it would be very much more difficult(if not impossible!) for me to try to to run two flat cables, side by side, with 'all four corners' touching, or nearly touching, the walls of the conduit, than to have just a single, round cable not much bigger than half the ID of the conduit, almost 'floating around' within the conduit (probably not touching the conduit in more than one place).
In fact, I could make life even easier for you since, at least in terms of my present requirements, I wouldn't need 2 x 3C+E - one 3C+E and one T+E would suffice at present.
