This is very interesting/intriguing...
People have been making all sorts of suggestions (about which I'm pretty nervous!) about getting umpteen cables/cores into the seemingly 'tiny' (maybe 5/8") conduit I'm dealing with, but it seems that whoever did the present wiring even had a problem getting one 1mm² 3C+E cable in!
I've now got that "3C+E" cable out, and drawn in a new length of 5-core flex. I commented before that I could not find he cable sheath at the bottom, so assumed it had been 'cut back', but there was no doubt that what was going into the top of the conduit was3C+E (with sheath). However, having now got it out, look what I found ....
.... There was, in fact, only one or two inches of sheath going into the top of the conduit. For the rest of the run down the conduit, the sheath had been stripped off, leaving just the cores (including the bare CPC), which were neatly taped together. I suppose that's not too far off Sunray's suggestion to"use singles", but I have to say that I've never previously seen it done in quite this way
0hhhh yes, not exactly uncommon.
What I will say is if that is an undamaged 5/8" or 16mm conduit of internal diameter around 14mm that 1mm² 3C&E should have almost fallen into it under it's own weight, assuming it hadn't been mangled by some monkey before hand.
