- Joined
- 14 Jul 2026
- Messages
- 27
- Reaction score
- 4
- Country
They were not they were taped up as not in use
You come on here asking for help.You can clearly see the two wires u claim came out did not ,taped up at back of box
Unless it has voltage reading capabilties then please dont as theyre useless for what you need.Im buying a voltage detector pen
I tried the taped up blue and black wires in the switch ,even though they are both live on testing made no difference, since then the other 3 wires on both upstairs and downstairs are all dead ,i did try to pull abit of extra cable through the old metal trunking thus afternoon and both ends are completely dead on testing now,I think I had a loose connection hence power coming and going on testing when wired up to switch, i guess there must be a junction box somewhere under the floorboards upstairsYou come on here asking for help.
Regardless of what YOU THINK; the advice given about 5 wires is totally correct.
What I see in you pictures is a yellow wire, correctly marked with red tape to indicate it's a live wire and a blue and a black wire, correctly marked with red tape to indicate it's a live wire.
Somehow the blue and black have become disassociated from the switch.
Do us all a favour and terminate the taped up blue and black in the spare terminal and try it.
THEN we can start with other advice IF it still does not work.
This is how it was wired when it was working properly:
Compare that with what you have now.
If you still have the green sleeving please put it back on the bare earth wires.
I will add: Well done for taking the 'before' pictures, it has helped us a lot knowing what was there.
I chucked the old switches away unfortunately, the only reason I have changed them is they are the old fashioned box switches, i wanted flush ones ,initially I changed the hallway no issues whatsoever, problem began when changing the one on the landingDid you put the old switches back on ,wired according to the way they were before removal, if so what was the result ?
That remain unanswered.As you left a few weeks between changing the hall switch ,and the issue that arose today,
Have you worked on any ceiling light fittings ,or any other switches between,or been in the loft ?
Voltsticks are very useful but have their limitationsAre you saying one of the wires that was originally taped up lights up your voltage sensor ,and no other wires do ?
You would be better off buying a multimeter ,those volt sticks are not gonna be much use to you for fault finding.
Yes ,it's possible that pulling on wires could cause a disconnection. So could many other things ,hence me asking the questions below.
