Two way lighting not working
Are you saying one of the wires that was originally taped up lights up your voltage sensor ,and no other wires do ?
You would be better off buying a multimeter ,those volt sticks are not gonna be much use to you for fault finding.
Yes ,it's possible that pulling on wires could cause a disconnection. So could many other things ,hence me asking the questions below.
That remain unanswered.
No issues with ceiling rose all connections secure
Pictures of the wiring connections at the rose may be useful.
If the permanent live to the switch originates there,that would be a starting point,followed by tracking the cable in the loft. Hopefully it's not boarded over up there and you can access the cables !
I got a loft conversion
