Would this be a fire risk?
5 Nov 2024
I have visited a property today and noticed the boiler cable just coiled up, rather than shorten it. I thought along the lines of an extension cable not fully unwound, but have I overthought it? I have shortened it myself on today's visit, but just wondered for future reference.
Additional Info: fed from CU to fcu with mcb/RCD protection. Fuse rating 3A.
I remember that you are interested in electical theory. Read up about current transdformers and how a long extension reel might be a cause for concern. That will set your mind at rest.
The heat generation is pretty much entirely resistive and the big problem with extension leads is lack of heat dissipation.
True- but, as has ben said, if it's just supplying a boiler then there is going to be very little heat to dissipate - and, in any event, all we're told is that 'the boiler cable is coiled up;, and I strongly suspect that that means an awful lot less 'coiling' than one gets in a 'drum' or 'cassette' type of extension reel!
Yes, there's not going to be metres and metres of flex and it won't be enclosed on a reel.
And even if it was, the amount of current drawn is not going to generate a excessive amount of heat. The heat that is, will dissipate easily, even if the flex is coiled.
My Father's second wife once plugged a fan heater into a coiled up extension lead.
It melted the flex together, but it was a 3kW heater on a 15m 5A lead. The lead was rated at 1200W fully unwound and 480w fully wound.
Yes, apologies, I thought I wrote the length. Supplied pre-wired to boiler approx 1m of 0.75mm sq 3 core flex. "Coiled up" is approx 500mm.
That's what I suspected. In that case, as has been implied, you're worrying about nothing- 'many metres', coiled up inside an enclosure of some sort, might possibly be be a problem (but only with loads very much greater than your boiler), but 0.5m is, really, 'absolutely nothing' :-)
