- Joined
- 27 Jan 2008
- Messages
- 29,495
- Reaction score
- 3,631
- Location
- Country
OK, thought may as well have a look, was a bit bored. So on the minus side
I can only see how heat pumps could be more efficient to the immersion heater, as to more expensive depending on local tariffs, yes good point.Can be less energy efficient than other systems like gas boilers or solar thermal, especially if used as the primary heating method. (-)
Requires electricity, which can be expensive depending on local tariffs. (-)
I think it is highly unlikely a gas boiler can be more energy-efficient. Note energy, not cost to run.Gas boilers, for instance, are often more energy-efficient for heating large volumes of water and providing central heating. Solar thermal systems utilize the sun's energy, offering significant long-term savings, although they require a higher initial investment. Tankless (on-demand) water heaters heat water only when needed, potentially saving energy compared to keeping a tank of water hot.
Solar thermal systems, often use an immersion heater, it is a more efficient way of transferring energy to using water.
So called tankless (on-demand) often use a small immersion heater, if electrically powered. Remember the article does include many types of immersion heater, not just the type which fits in a large storage tank.
OK, my immersion heater does have the option to run on a timer, and to detect when solar production is being exported, so it is likely cheaper to run than systems with just a thermostat and cut out.
But why have we, it seems, been brainwashed that the immersion is expensive? When the central heating is already running, then yes it works our cheaper to using a large storage tank immersion heater, due to electric prices in the UK being tied to gas, so gas is always cheaper. But moving energy with wires, is far more efficient to moving it with water in pipes, and also if a boiler is cold, the energy used to heat it up before even one drop of hot water is used, has to be factored in.
So likely the under sink immersion heater is overall the most efficient, as hardly any energy wasted heating pipes. The instant water heater even better, but there is a problem getting enough power to the heater, which technically is still an immersion heater, so to reduce cable sizes required, the small water store around 7 litres and an immersion is likely best option.
However for example with this house, it would require 5 units instead of one, and they are not big enough to fill a bath, at least within a reasonable time, and this goes for any instant heater too, be it electric or gas, the time to fill a bath is doubled if not using stored hot water.
OK I rarely use a bath, and instant electric works well for a shower, be it from instant gas, or stored DHW, the delay between switch on and hot water at the shower, can be a problem with a small shower cubical where one can't step out of the water flow.
Instant electric showers can be more expensive to run, as often they use more current to what a battery storage system can provide, but the amount used is so small, it is hardly worth worrying about.
So yes I use oil to heat DHW when the CH is running, but at any other time the immersion heater is likely cheaper, even when electric is 5 times the price.
So why is there so much miss information about immersion heaters. Is it from the days when we had no insulation around the cylinder?
When we have off-peak, having the immersion on a timer makes sense, but unless electric is cheaper at some time of the day, timers are pointless. A 40 gallon tank will stay hot for 2 days.
