Have you checked how much end bearing there is
No, I'm not there until tomorrow. I'll see if I can measure it from behind off steps and will measure the full length of the beam as well. But that is only of use when we get to see the calcs and check if it complies with the SE drawings.Have you checked how much end bearing there is
Any ideas how much that would cost, the job is in Manchester area ?If it were me, I would be getting an independent SE out to check it. Then, go from there...
Sorry, no idea....but it's what I would do. Got to think long term, peace of mind.Any ideas how much that would cost, the job is in Manchester area ?
An SE can likely prove that what is there, will work with some remedial repairs - beam end bearing included. Bear in mind that 100mm end bearing is the benchmark minimum.Any ideas how much that would cost, the job is in Manchester area ?
The costs would be paid for by the builder if there is a problem.Any ideas how much that would cost, the job is in Manchester area ?
Not strictly true. Large padstones with heavy loads may be twice the size of the load area.The entire reason for a padstone's existence is to spread a point load across a wider area. If you stick it on edge then it's not a padstone, you may as well not bother.
No. The whole point is not to spread the load, but to prevent local bearing stress shearing the wall directly below the beam.The entire reason for a padstone's existence is to spread a point load across a wider area. If you stick it on edge then it's not a padstone, you may as well not bother.
Exactly. The builder has shot himself in the foot, because he has no get-out. By using his own SE, he's changed a build-contract with no design risk because that was initially done by others, to a D&B without making any allowance for the risks and liabilities. More to the point, who is now the "principal designer" under the BSA and is going to sign-off the completion? The builder, I'm sure, doesn't realise (yet) what a mess he has caused. Your son, however should never have allowed the design to be moved away from his own team.He confirmed that as the builder used his own SE then the builder is responsible for the design not my son.
Because the local bearing stress does not need to be reduced to an acceptable level by using padstones at a guess?No. The whole point is not to spread the load, but to prevent local bearing stress shearing the wall directly below the beam.
Why don't lintels require padstones?
NHBC state minimum of 100mm but at the end of the day actual bearing should be confirmed by load calculationsI measured the bearings before he came
Steel 1 is 10.5m long and has a 100mm bearing at one end (the one that cracked and he repaired) and 150mm bearing at the other end that hasn't cracked so far. That to me is way too short, 200mm at least
