Slip a putlog scaffold bar over the handle and the nut is coming off or the stud will break.
And then walk away, leaving it for someone else to sort out
ReportedIts still a clamp.
Oh hell yeahAnd then walk away, leaving it for someone else to sort out![]()
scaffold barWhats a putlong? Summat to do with golf?
scaffold bar
More like an early Footprint.It’s just an early Stillson
correct, it is when scaffolding was used when they were made from wood, the putlog was the short section of scaffold that ties the main poles to the building, they would make a hole in the side of the building that the pole would fit into. The term was "put log in the hole" so hence the name putlog.Sounds like putlog, a medieval building term.
Not at all. A footprint is the smaller and weaker version of the Stilson pipe wrench. The tool in question is an early adjustable spanner used for nuts mainly for British rail and steam engineering. and not a pipe wrench. I only deal in facts.More like an early Footprint.
Or thatMore like an early Footprint.
Nothing like itOr that
Its nothing like anything current, except it's an adjustable spannerNothing like it
