Floating Floor Threshold and make up
19 Jul 2022
South West UK
Hi, as part of ongoing garage conversion - can only squeeze in 50 - 60 mm insulation (which BC is happy with) but -
1) Is there a preferred way to support the threshold to keep it sound long term? Red section below will be main through-fare as there will be units to the left and right. I'm thinking treated timber on a bed of some kind of fixative to give a level setting on the slightly rough surface - photo makes it look a lot worse that it is. Then wrap DPM over the top to lie on the DPC - which will be reinstated between the 2 tabs shown?
2) I need to make up 78 mm so if I go 50mm insulation + preferred 22mm MR T&G Boards leaves me around 5-6 short so hardboard / plywood on top of floorboards? Or I just go 60 insulation + 18mm T&G... I've always just preferred the thicker floorboards in the past.
Cheers
Cheers
Firstly, those bricks in the red box have to go.
By the time you have laid a bit of blinding sand, DPM and your insulation, glued floor deck, you will find it will line up perfectly.
Could use a self leveler as only 5mm approx.
Then the 50mm insulation and 22mm flooring.
Thanks. The last metre and a half of the garage floor to the left in the photo does have a 15mm slope so it was in my mind to use leveller for that. I could mix up some extra - looks like it will be around 5 bags worth in total - to raise the rest of the floor, but I’ve not had a lot of experience with leveller. Just how good is it to self level that sort of area for a 3 to 5mm ?
Cheers, hadn’t considered those bricks, they look pretty solid but yes they have not had any traffic over them previously.
Should I backfill with concrete seeing as it’s under the DPC?
Then re levelling - just to check, are you basing that on the sand etc making up the 78mm based on the 50mm PIR and 22mm boards? As above I do have the option of leveller but if you think the sand etc will do it that’s a nicer option.
Ta
Ta
Yes. Do a dummy run and see where your levels sit. Use sand under the DPM to make up a few mm if necessary. You may not need any or just a smattering by the join.
