Best type and make of replacement Stopcock
5 Nov 2021
Gloucestershire
Hi, any recommendations on best make and type to replace this old seized, leaking stopcock? I don't want to scrimp.
I'd prefer quarter turn unless advised otherwise. Would also prefer to go plastic pipe after the tap but again happy to take advice.
Also just trying to understand how the lower compression fitting section is fitted to that upper larger nut, will there be a stub screwed in to that larger upper nut which will need replacing as well to give a clean stub to fit back on to?
TIA
Peglar stop tap.
1.40 in shows you connection.
Can you not free up and clean the one you have?
Peglar stop tap.
Thanks for that, I’ll go for the Pegler by the looks of it.
My existing tap is slightly different to the one in the video, that one looks to have the 25mm connection directly on the bottom of the tap whereas mine looks to have a smaller 15mm compression fitting on top of the larger fittings as per photo below.
I’m wanting to change as it’s a 50 year old install and everything else in the kitchen is being replaced brand new so was a peace of mind thing really. I’ll have a look to see how fixable it is, if I can avoid then no prob.
Cheers
Go 1/4 turn - most are decent. Just make sure it's suitable for potable water
Ah. Missed that.
It's just a case often of force turning to free up.
Then a tiny nip of the nut and the button of the turning shaft as they all leak there a bit.
If that works leave it.
Thanks all - much appreciated.
I'd rather replace the stopcock, not just for 1/4 turn ease but it's leaking out the stem and the top ferrule ... and also the nut and shaft look knackered.
I've picked up the Pegler Valve - but what is the lesser of the 2 evils ? cutting off the lower olive on that existing 15mm upstand and fitting the Pegler to that with a fresh olive - or replacing the whole thing with one of these below (including pipe insert) ?
Not worried about cost at all and would like to think that everything is new for peace of mind but I know theres a lot to be said for if its ok just leave it, but its all very old and will be nice to spruce it all up.
Thank you all again.
Cheers
The existing MDPE reducer will be absolutely fine to leave, but only you can decide if you want to replace it for peace of mind. If it will bother you in the future then just change everything.
Get a 25mm mdpe elbow.
A reducing set to replace the 25mm collet and O ring in that elbow.
Stick a bit of 15mm copper into it.
Put in a lever valve (making sure you'll be able to operate it when it's below/inside the Kitchen unit when it's fitted) and then onto the 15mm house supply you have there.
Thank you.
Sorry Im a bit dense and have only worked with 15mm plastic before not 25 mdpe but are you saying to kick the 25mm over 90 degrees just after it comes out the floor - using a push fit 25 mdpe elbow, then use the adapter in my photo above, then copper and then the 1/4 turn?
Its a belfast sink so not a lot of room in the lower cupboard and I was thinking about running the feed horizontally UNDER the cabinet to then bring it up the rear wall and have the 1/4 turn vertical behind the cabinet with an access hole in the back of the cabinet to get access.
Also is it ok to run 15mm plastic from that adapter to the 1/4 turn or is it best to switch to plastic after the 1/4 turn?
Many thanks - really appreciate the help.
