Most systems though would benefit without this possible source of confusion though
Yes add a plug in rcd if you like when working outdoorsMost systems though would benefit without this possible source of confusion though![]()
Yes the TD rcd upfront is a separate matter to the 2 30ma in seriesAnyway, remember when one popular way of wiring for TT on a consumer unit - One RCD 100mA time delayed connected for all ways and One RCD fed from that one for only 30mA RCD circuits.
Lighting on the 100mA delayed only and Power on both RCDs
The caravan maybe?Doesn't mean it doesn't provide added security but you won't find it in any electrical design that im aware of
The caravan maybe?
In the main RCDs increase by a factor of 3, so 10 mA, 30 mA, 100 mA, 300 mA, 500mA, 1 amp, 5 amp. The 300 mA for fire and 30 mA for personal means no all steps are a factor of 3.
As to why on caravan sites we have a 30 mA feeding a 30 mA I would assume in case one is missing.
As to the flymo RCD, still here on table, not binned yet, the lack of test button is interesting, and also the way the shutters seem to press the relay. OK I do have an RCD tester, but I would think that is unusual for a retired electrician, but since I never got the RCD to work, I was never able to test it.
The way the shutter pushed the relay manually in openning only, did seem odd, The N/C contacts which were opened when the plug was inserted made some sense.
But this is the only RCD I have come across where the inserting and removing of the plug did all the testing of the device.
And similarly the narrowboat.The caravan maybe?
Well spotted, suppose time it went in the bin.Happy birthday to you,
37 this month![]()
1st point - rodger that one.When going my site temporaries I always add my own RCD, even if I'm collecting power from a RCD socket which operates when I press the button.
However I do find that there is a much higher chance of tripping with more and more RCDs in line which is something I can't explain.
It wasn't that long ago RCDs were only fitted to socket circuitsThe big problem with a RCD, is testing it actually works. With a socket circuit, easy enough to plug in press the button and see it trip. But with an immersion heater, cooker etc, for me, it means standing on some form of step up to reach the consumer unit, remove the cover and earth wire to the cover, try to balance the tester somewhere, hold on two leads, and press the test button.
So sockets tested around once every 6 months, but the rest, likely never tested since they were fitted.
But in the main, the most likely circuit to get a shock from is the socket circuit, but even with the socket circuit. The two double RCD sockets easy to test, the rest to go down to reset, and to correct all the clocks, rare to test, until something goes wrong.
I was considering getting these, then banned for domestic, the ones with warning windows seemed next option
I know hunting the internet for Xpole did get some ammusing results, think they were more akin to other meaning of RCD recreational craft directive, at least the recreational bit.
