I've got a Texecom Premier Elite 12 which had been powered down for about a year until recently when I got it back up and running.
I've got 2 x door contacts and 1 x PIR that are wireless Ricochet devices and after powering up the system, the wireless PIR was reporting low battery which I replaced with brand new out of packet battery. PIR still reporting low battery. Tried the other new battery (2 in packet) but the same. Checked the batteries with a tester to confirm ok, and even the one originally in the PIR was showing as still pretty decent. As the PIR quite old and looking online which said sometimes problems with the tamper switches can report as low battery figured PIR must've gone faulty so removed it from the panel and ordered a new one.
My panel was on firmware version 2.10 so in the meantime I flashed the firmware to the latest v6 version which went as it should. The new PIR turned up yesterday so learned it with the panel which went as expected... but that too is showing a low battery fault! The new PIR came with a new battery too.
New PIR, another new battery, reporting a low battery fault - something other than the PIR must be generating the low battery fault...
Anyone any suggestions / ideas?
