Laying off of rollered gloss
7 Oct 2024
Am about to try, for the first time, roller-applying gloss on an exterior (single) door. I understand the concept of laying off with a dry brush, but I'm pondering a couple of aspects:
How soon does the brush become not 'dry' enough and what do you do with it then before continuing?
Is it best to roller the whole door then lay off, or do it in several areas, one at a time?
Suggestions/experiences welcomed.
Tip off before gloss skins.
Depends on what gloss and drying conditions.
Roll door takes say 2 mins then tip off which is another 2 mins.
As for brush normally have two.
With water based paint I would wash out. Stand on cardboard. Lift toes up and bang brush on end of boot so water flows out on cardboard.
Keep brush damp ready to tip off next door or whatever you are painting.
If oil paint wrap in cling film.
Wash out with white spirit and bang on foot catching white spirit on cardboard if required. Oil stays wetter than water based
Painting your front door - if that's what it is - may not be the right place to prefer speed over quality. Is it a plain door, or does it have glazing or other features?
Not that I know much about the subject! I defer to the actual decorators.
Just a couple of side doors on the garage, so a mirror finish isn't essential. Not glazed or owt, just t&g with bracing.
Given that they are T&G, as as decorator, I would stick with a brush.
You are going to need to use a brush to get into the grooves regardless.
Are you using water based or oil based paint?
If oil based, you can add Owatrol oil to extend the wet edge time. It isn't cheap but you only only need a small amount.
If waterbased, you can use Floetrol- again not cheap- propylene glycol is cheaper.
